Touch Bar Widget script not running after waking from sleep
I have a touch bar button for a Do Not Disturb mode that's having an icon who's color changes dynamically based on the outcome of custom applescript. That widget script doesn't seem to be running (periodically) after waking from sleep. If I restart BetterTouchTool, it still won't set the color properly. If I click 'Run Script' in BetterTouchTool, still the same.
If I push the Touch Bar button once, it will toggle my DND mode, set the color property correctly and then it will run properly periodically from that point in time (once in every minute).
Is it possible something is misconfigured on the Widget?
macOS Ventura 13.6.1
BetterTouchTool 4.334
The button configuration and the script are pasted below.
    "BTTLastUpdatedAt" : 1701806194.3784971,
    "BTTTriggerType" : 639,
    "BTTTriggerTypeDescription" : "Apple Script \/ JavaScript Widget",
    "BTTTriggerClass" : "BTTTriggerTypeTouchBar",
    "BTTPredefinedActionType" : 292,
    "BTTPredefinedActionName" : "Assign\/Set Value for Variable",
    "BTTGenericActionConfig2" : "true",
    "BTTVariableName" : "focusToggledViaControlStrip",
    "BTTVariableValue" : "true",
    "BTTActionURLToLoad" : "focusToggledViaControlStrip",
    "BTTActionFloatingHTMLConfig" : "true",
    "BTTUUID" : "E5611CB3-DE4D-4980-BB12-A93E79CA040A",
    "BTTEnabled" : 1,
    "BTTEnabled2" : 1,
    "BTTOrder" : 5,
    "BTTDisplayOrder" : 1000,
    "BTTMergeIntoTouchBarGroups" : 1,
    "BTTAdditionalActions" : [
        "BTTLastUpdatedAt" : 1695330735.469228,
        "BTTTriggerParentUUID" : "E5611CB3-DE4D-4980-BB12-A93E79CA040A",
        "BTTPredefinedActionType" : 200,
        "BTTPredefinedActionName" : "Toggle Do Not Disturb On\/Off",
        "BTTAdditionalActionData" : {
          "BTTScriptType" : 0,
          "BTTAppleScriptRunInBackground" : true,
          "BTTTouchBarAppleScriptString" : "display notification \"Enabled\" with title \"Do Not Disturb\"",
          "BTTTouchBarAppleScriptUsePath" : false
        "BTTGenericActionConfig" : "display notification \"Enabled\" with title \"Do Not Disturb\"",
        "BTTUUID" : "F8D28FA5-03CF-43DC-9FDF-304335E7D4D1",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 0,
        "BTTIconData" : "TU0AKgAAD_gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAE0ACgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBAM8ArAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACACOAP4A_wA7AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEADFAP8A_wDjAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFQDQAP8A_wD_AJYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQDDAP8A_wD_AP8AYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACVAP8A_wD_AP8A_wAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+AP8A_wD_AP8A_wD_ABgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACANAA_wD_AP8A_wD_AP8ACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFYA_wD_AP8A_wD_AP8A_wAGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAvAD_AP8A_wD_AP8A_wD_ABMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIQD+AP8A_wD_AP8A_wD_AP8AMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABrAP8A_wD_AP8A_wD_AP8A_wBaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKUA_wD_AP8A_wD_AP8A_wD_AJcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0QD_AP8A_wD_AP8A_wD_AP8A3QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADtAP8A_wD_AP8A_wD_AP8A_wD_ADoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPsA_wD_AP8A_wD_AP8A_wD_AP8ApgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+QD_AP8A_wD_AP8A_wD_AP8A_wD8ACgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADsAP8A_wD_AP8A_wD_AP8A_wD_AP8AugAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM4A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AGYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A9wA0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABoAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AOoAJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACIA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wDqADQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADFAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A9wBmAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFkA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AuwAoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwDXAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_APwApgA6AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABABsAAAAAAEUA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A3QCXAFoAMQATAAYABgATADIAWwCYAN4AOwAAAAAAAACZAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AkgAAAAAAAAAAAAgAywD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AwAAFAAAAAAAAAAAAAAAVANgA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A0wATAAAAAAAAAAAAAAAAAAAAFQDLAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AxAARAAAAAAAAAAAAAAAAAAAAAAAAAAgAmQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP4AkQAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEUA1wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_ANEAQwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAFkAxQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_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_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_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_kEBgQTBCAELQQ7BEgEVQRjBHEEfgSMBJoEqAS2BMQE0wThBPAE_gUNBRwFKwU6BUkFWAVnBXcFhgWWBaYFtQXFBdUF5QX2BgYGFgYnBjcGSAZZBmoGewaMBp0GrwbABtEG4wb1BwcHGQcrBz0HTwdhB3QHhgeZB6wHvwfSB+UH+AgLCB8IMghGCFoIbgiCCJYIqgi+CNII5wj7CRAJJQk6CU8JZAl5CY8JpAm6Cc8J5Qn7ChEKJwo9ClQKagqBCpgKrgrFCtwK8wsLCyILOQtRC2kLgAuYC7ALyAvhC_kMEgwqDEMMXAx1DI4MpwzADNkM8w0NDSYNQA1aDXQNjg2pDcMN3g34DhMOLg5JDmQOfw6bDrYO0g7uDwkPJQ9BD14Peg+WD7MPzw_sEAkQJhBDEGEQfhCbELkQ1xD1ERMRMRFPEW0RjBGqEckR6BIHEiYSRRJkEoQSoxLDEuMTAxMjE0MTYxODE6QTxRPlFAYUJxRJFGoUixStFM4U8BUSFTQVVhV4FZsVvRXgFgMWJhZJFmwWjxayFtYW+hcdF0EXZReJF64X0hf3GBsYQBhlGIoYrxjVGPoZIBlFGWsZkRm3Gd0aBBoqGlEadxqeGsUa7BsUGzsbYxuKG7Ib2hwCHCocUhx7HKMczBz1HR4dRx1wHZkdwx3sHhYeQB5qHpQevh7pHxMfPh9pH5Qfvx_qIBUgQSBsIJggxCDwIRwhSCF1IaEhziH7IiciVSKCIq8i3SMKIzgjZiOUI8Ij8CQfJE0kfCSrJNolCSU4JWgllyXHJfcmJyZXJocmtyboJxgnSSd6J6sn3CgNKD8ocSiiKNQpBik4KWspnSnQKgIqNSpoKpsqzysCKzYraSudK9EsBSw5LG4soizXLQwtQS12Last4S4WLkwugi63Lu4vJC9aL5Evxy_+MDUwbDCkMNsxEjFKMYIxujHyMioyYzKbMtQzDTNGM38zuDPxNCs0ZTSeNNg1EzVNNYc1wjX9Njc2cjauNuk3JDdgN5w31zgUOFA4jDjIOQU5Qjl_Obw5+To2OnQ6sjrvOy07azuqO+g8JzxlPKQ84z0iPWE9oT3gPiA+YD6gPuA_IT9hP6I_4kAjQGRApkDnQSlBakGsQe5CMEJyQrVC90M6Q31DwEQDREdEikTORRJFVUWaRd5GIkZnRqtG8Ec1R3tHwEgFSEtIkUjXSR1JY0mpSfBKN0p9SsRLDEtTS5pL4kwqTHJMuk0CTUpNk03cTiVObk63TwBPSU+TT91QJ1BxULtRBlFQUZtR5lIxUnxSx1MTU19TqlP2VEJUj1TbVShVdVXCVg9WXFapVvdXRFeSV+BYL1h9WMtZGllpWbhaB1pWWqZa9VtFW5Vb5Vw1XIZc1l0nXXhdyV4aXmxevV8PX2Ffs2AFYFdgqmD8YU9homH1YklinGLwY0Njl2PrZEBklGTpZT1lkmXnZj1mkmboZz1nk2fpaD9olmjsaUNpmmnxakhqn2r3a09rp2v_bFdsr20IbWBtuW4SbmtuxG8eb3hv0XArcIZw4HE6cZVx8HJLcqZzAXNdc7h0FHRwdMx1KHWFdeF2Pnabdvh3VnezeBF4bnjMeSp5iXnnekZ6pXsEe2N7wnwhfIF84X1BfaF+AX5ifsJ_I3+Ef+WAR4CogQqBa4HNgjCCkoL0g1eDuoQdhICE44VHhauGDoZyhteHO4efiASIaYjOiTOJmYn+imSKyoswi5aL_IxjjMqNMY2Yjf+OZo7OjzaPnpAGkG6Q1pE_kaiSEZJ6kuOTTZO2lCCUipT0lV+VyZY0lp+XCpd1l+CYTJi4mSSZkJn8mmia1ZtCm6+cHJyJnPedZJ3SnkCerp8dn4uf+qBpoNihR6G2oiailqMGo3aj5qRWpMelOKWpphqmi6b9p26n4KhSqMSpN6mpqhyqj6sCq3Wr6axcrNCtRK24ri2uoa8Wr4uwALB1sOqxYLHWskuywrM4s660JbSctRO1irYBtnm28Ldot+C4WbjRuUq5wro7urW7LrunvCG8m70VvY++Cr6Evv+_er_1wHDA7MFnwePCX8Lbw1jD1MRRxM7FS8XIxkbGw8dBx7_IPci8yTrJuco4yrfLNsu2zDXMtc01zbXONs62zzfPuNA50LrRPNG+0j_SwdNE08bUSdTL1U7V0dZV1tjXXNfg2GTY6Nls2fHadtr724DcBdyK3RDdlt4c3qLfKd+v4DbgveFE4cziU+Lb42Pj6+Rz5PzlhOYN5pbnH+ep6DLovOlG6dDqW+rl63Dr++yG7RHtnO4o7rTvQO_M8Fjw5fFy8f_yjPMZ86f0NPTC9VD13vZt9vv3ivgZ+Kj5OPnH+lf65_t3_Af8mP0p_br+S_7c_23__w==",
        "BTTAlternateIconData" : "TU0AKgAAD_gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAE0ACgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBAM8ArAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACACOAP4A_wA7AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEADFAP8A_wDjAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFQDQAP8A_wD_AJYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQDDAP8A_wD_AP8AYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACVAP8A_wD_AP8A_wAwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+AP8A_wD_AP8A_wD_ABgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACANAA_wD_AP8A_wD_AP8ACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFYA_wD_AP8A_wD_AP8A_wAGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAvAD_AP8A_wD_AP8A_wD_ABMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIQD+AP8A_wD_AP8A_wD_AP8AMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABrAP8A_wD_AP8A_wD_AP8A_wBaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKUA_wD_AP8A_wD_AP8A_wD_AJcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0QD_AP8A_wD_AP8A_wD_AP8A3QAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADtAP8A_wD_AP8A_wD_AP8A_wD_ADoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPsA_wD_AP8A_wD_AP8A_wD_AP8ApgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA+QD_AP8A_wD_AP8A_wD_AP8A_wD8ACgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADsAP8A_wD_AP8A_wD_AP8A_wD_AP8AugAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAM4A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AGYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A9wA0AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABoAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AOoAJwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACIA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wDqADQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADFAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A9wBmAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFkA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AuwAoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAwDXAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_APwApgA6AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABABsAAAAAAEUA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A3QCXAFoAMQATAAYABgATADIAWwCYAN4AOwAAAAAAAACZAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AkgAAAAAAAAAAAAgAywD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AwAAFAAAAAAAAAAAAAAAVANgA_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A0wATAAAAAAAAAAAAAAAAAAAAFQDLAP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8AxAARAAAAAAAAAAAAAAAAAAAAAAAAAAgAmQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP4AkQAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEUA1wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_wD_ANEAQwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAFkAxQD_AP8A_wD_AP8A_wD_AP8A_wD_AP8A_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_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_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_kEBgQTBCAELQQ7BEgEVQRjBHEEfgSMBJoEqAS2BMQE0wThBPAE_gUNBRwFKwU6BUkFWAVnBXcFhgWWBaYFtQXFBdUF5QX2BgYGFgYnBjcGSAZZBmoGewaMBp0GrwbABtEG4wb1BwcHGQcrBz0HTwdhB3QHhgeZB6wHvwfSB+UH+AgLCB8IMghGCFoIbgiCCJYIqgi+CNII5wj7CRAJJQk6CU8JZAl5CY8JpAm6Cc8J5Qn7ChEKJwo9ClQKagqBCpgKrgrFCtwK8wsLCyILOQtRC2kLgAuYC7ALyAvhC_kMEgwqDEMMXAx1DI4MpwzADNkM8w0NDSYNQA1aDXQNjg2pDcMN3g34DhMOLg5JDmQOfw6bDrYO0g7uDwkPJQ9BD14Peg+WD7MPzw_sEAkQJhBDEGEQfhCbELkQ1xD1ERMRMRFPEW0RjBGqEckR6BIHEiYSRRJkEoQSoxLDEuMTAxMjE0MTYxODE6QTxRPlFAYUJxRJFGoUixStFM4U8BUSFTQVVhV4FZsVvRXgFgMWJhZJFmwWjxayFtYW+hcdF0EXZReJF64X0hf3GBsYQBhlGIoYrxjVGPoZIBlFGWsZkRm3Gd0aBBoqGlEadxqeGsUa7BsUGzsbYxuKG7Ib2hwCHCocUhx7HKMczBz1HR4dRx1wHZkdwx3sHhYeQB5qHpQevh7pHxMfPh9pH5Qfvx_qIBUgQSBsIJggxCDwIRwhSCF1IaEhziH7IiciVSKCIq8i3SMKIzgjZiOUI8Ij8CQfJE0kfCSrJNolCSU4JWgllyXHJfcmJyZXJocmtyboJxgnSSd6J6sn3CgNKD8ocSiiKNQpBik4KWspnSnQKgIqNSpoKpsqzysCKzYraSudK9EsBSw5LG4soizXLQwtQS12Last4S4WLkwugi63Lu4vJC9aL5Evxy_+MDUwbDCkMNsxEjFKMYIxujHyMioyYzKbMtQzDTNGM38zuDPxNCs0ZTSeNNg1EzVNNYc1wjX9Njc2cjauNuk3JDdgN5w31zgUOFA4jDjIOQU5Qjl_Obw5+To2OnQ6sjrvOy07azuqO+g8JzxlPKQ84z0iPWE9oT3gPiA+YD6gPuA_IT9hP6I_4kAjQGRApkDnQSlBakGsQe5CMEJyQrVC90M6Q31DwEQDREdEikTORRJFVUWaRd5GIkZnRqtG8Ec1R3tHwEgFSEtIkUjXSR1JY0mpSfBKN0p9SsRLDEtTS5pL4kwqTHJMuk0CTUpNk03cTiVObk63TwBPSU+TT91QJ1BxULtRBlFQUZtR5lIxUnxSx1MTU19TqlP2VEJUj1TbVShVdVXCVg9WXFapVvdXRFeSV+BYL1h9WMtZGllpWbhaB1pWWqZa9VtFW5Vb5Vw1XIZc1l0nXXhdyV4aXmxevV8PX2Ffs2AFYFdgqmD8YU9homH1YklinGLwY0Njl2PrZEBklGTpZT1lkmXnZj1mkmboZz1nk2fpaD9olmjsaUNpmmnxakhqn2r3a09rp2v_bFdsr20IbWBtuW4SbmtuxG8eb3hv0XArcIZw4HE6cZVx8HJLcqZzAXNdc7h0FHRwdMx1KHWFdeF2Pnabdvh3VnezeBF4bnjMeSp5iXnnekZ6pXsEe2N7wnwhfIF84X1BfaF+AX5ifsJ_I3+Ef+WAR4CogQqBa4HNgjCCkoL0g1eDuoQdhICE44VHhauGDoZyhteHO4efiASIaYjOiTOJmYn+imSKyoswi5aL_IxjjMqNMY2Yjf+OZo7OjzaPnpAGkG6Q1pE_kaiSEZJ6kuOTTZO2lCCUipT0lV+VyZY0lp+XCpd1l+CYTJi4mSSZkJn8mmia1ZtCm6+cHJyJnPedZJ3SnkCerp8dn4uf+qBpoNihR6G2oiailqMGo3aj5qRWpMelOKWpphqmi6b9p26n4KhSqMSpN6mpqhyqj6sCq3Wr6axcrNCtRK24ri2uoa8Wr4uwALB1sOqxYLHWskuywrM4s660JbSctRO1irYBtnm28Ldot+C4WbjRuUq5wro7urW7LrunvCG8m70VvY++Cr6Evv+_er_1wHDA7MFnwePCX8Lbw1jD1MRRxM7FS8XIxkbGw8dBx7_IPci8yTrJuco4yrfLNsu2zDXMtc01zbXONs62zzfPuNA50LrRPNG+0j_SwdNE08bUSdTL1U7V0dZV1tjXXNfg2GTY6Nls2fHadtr724DcBdyK3RDdlt4c3qLfKd+v4DbgveFE4cziU+Lb42Pj6+Rz5PzlhOYN5pbnH+ep6DLovOlG6dDqW+rl63Dr++yG7RHtnO4o7rTvQO_M8Fjw5fFy8f_yjPMZ86f0NPTC9VD13vZt9vv3ivgZ+Kj5OPnH+lf65_t3_Af8mP0p_br+S_7c_23__w==",
        "BTTWidgetName" : "Do Not Disturb",
        "BTTTriggerConfig" : {
          "BTTTouchBarButtonColor" : "55.000000, 55.000000, 55.000000, 255.000000",
          "BTTTouchBarButtonUseFixedWidth" : 1,
          "BTTTouchBarIconInvert" : false,
          "BTTTouchBarFreeSpaceAfterButton" : 0,
          "BTTTouchBarItemIconType" : 1,
          "BTTTouchBarAppleScriptString" : "return do shell script \"date\" #example: execute a shell script and use the result",
          "BTTTouchBarButtonFixedWidthCutOff" : 0,
          "BTTTouchBarAppleScriptStringRunOnInit" : false,
          "BTTTouchBarButtonHeight" : 15,
          "BTTTouchBarButtonCornerRadius" : 6,
          "BTTTouchBarItemIconWidth" : 26,
          "BTTTouchBarFontColorAlternate" : "98.000000, 89.000000, 208.000000, 255.000000",
          "BTTTBWidgetWidth" : 400,
          "BTTTouchBarButtonHoverColor" : "248.880000, 146.115000, 128.010000, 181.050000",
          "BTTTouchBarFontColor" : "255, 255, 255, 255",
          "BTTTouchBarAppleScriptUsePath" : 1,
          "BTTTouchBarOnlyShowIcon" : true,
          "BTTTouchBarAlternateBackgroundColor" : "55.000000, 55.000000, 55.000000, 255.000000",
          "BTTTouchBarApplyCornerRadiusTo" : 2,
          "BTTTouchBarFreeSpaceBeforeButton" : 0,
          "BTTTouchBarAlwaysShowButton" : false,
          "BTTTouchBarItemPadding" : 0,
          "BTTTouchBarItemPlacement" : 2,
          "BTTTouchBarButtonFontSize" : 15,
          "BTTTouchBarItemSFSymbolDefaultIcon" : "moon.fill",
          "BTTTouchBarScriptUpdateInterval" : 40,
          "BTTTouchBarItemIconHeight" : 26,
          "BTTTouchBarAppleScriptPath" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/showfocusstatus.scpt",
          "BTTTouchBarIconTextOffset" : 5,
          "BTTTouchBarButtonWidth" : 60,
          "BTTTouchBarBorderColor" : "255.000000, 255.000000, 255.000000, 255.000000",
          "BTTTouchBarColorRegex" : "enabled"
        "BTTLastUpdatedAt" : 1695330735.4691939,
        "BTTTriggerType" : -1,
        "BTTIsPureAction" : true,
        "BTTPredefinedActionType" : 345,
        "BTTPredefinedActionName" : "Delay Next Action (async \/ not blocking)",
        "BTTDelayNextActionBy" : "0.6",
        "BTTUUID" : "6B0529FD-1511-48E5-95A5-CA9048A1A9A4",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 1,
        "BTTMergeIntoTouchBarGroups" : 0
        "BTTLastUpdatedAt" : 1695330735.4692369,
        "BTTPredefinedActionType" : 195,
        "BTTPredefinedActionName" : "Run Apple Script (async in background)",
          "BTTTouchBarAppleScriptPath" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/togglebttfocusbutton.scpt",
          "BTTAppleScriptRunInBackground" : false,
          "BTTTouchBarAppleScriptString" : "#Insert script code here",
          "BTTTouchBarAppleScriptUsePath" : true
        "BTTGenericActionConfig2" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/togglebttfocusbutton.scpt",
        "BTTAppleScriptFilePath" : "\/opt\/dev\/github.com\/mkozjak\/bettertouchtool\/togglebttfocusbutton.scpt",
        "BTTInlineAppleScript" : "#Insert script code here",
        "BTTUUID" : "ABB59F2B-A9A1-4C25-9BCB-8581CFD67758",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 2,
        "BTTLastUpdatedAt" : 1695330740.8051901,
        "BTTUUID" : "21C5273C-F03A-4088-A355-5091B979ED2A",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 3,
        "BTTLastUpdatedAt" : 1695555236.511199,
        "BTTGenericActionConfig2" : "false",
        "BTTVariableValue" : "false",
        "BTTActionFloatingHTMLConfig" : "false",
        "BTTUUID" : "A5846E0F-A633-49F0-9142-1E7034F8E8AE",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 4,
        "BTTTouchBarButtonName" : "Do Not Disturb",
          "BTTTouchBarFontColor" : "98, 89, 208, 255",
          "BTTTouchBarScriptUpdateInterval" : 30,
      "BTTTouchBarFontColor" : "124, 113, 255, 255",
      "BTTTouchBarScriptUpdateInterval" : 60,
The applescript is:
tell application "Shortcuts Events"
        set manualToggle to get_string_variable "focusToggledViaControlStrip"
    end tell
    set focus to run shortcut "Get Current Focus"
    if length of focus is greater than 0 then
        set focusString to item 1 of focus as string
        if focusString is equal to "Do Not Disturb" then
            if manualToggle is equal to "true" then
                    update_trigger "E5611CB3-DE4D-4980-BB12-A93E79CA040A" json "{\"BTTTriggerConfig\": {\"BTTTouchBarFontColor\": \"124, 113, 255, 255\"}}"
                end tell
            end if
            return "enabled"
        else
                    update_trigger "E5611CB3-DE4D-4980-BB12-A93E79CA040A" json "{\"BTTTriggerConfig\": {\"BTTTouchBarFontColor\": \"255, 255, 255, 255\"}}"
                end tell
            end if
            return "disabled"
        end if
    else
            end tell
        end if
        return "disabled"
    end if
end tell
This still doesn't seem to be working. Here's my config just in case.
If I click on the "Run script" button in BetterTouchTool, it runs the script and updates the button accordingly. Might this be some long-standing bug or a misconfiguration on my end, @Andreas_Hegenberg?
macOS Ventura 13.6.7
BetterTouchTool 4.598
    "BTTActionCategory" : 0,
    "BTTLastUpdatedAt" : 1720780458.2348609,
    "BTTTriggerTypeDescriptionReadOnly" : "Apple Script \/ JavaScript Widget",
    "BTTTriggerTypeDescription" : "Do Not Disturb",
    "BTTPredefinedActionName" : "Assign or Set Value for Variable",
    "BTTEnabled" : 1,
    "BTTEnabled2" : 1,
    "BTTOrder" : 5,
        "BTTLastUpdatedAt" : 1716294724.438719,
        "BTTPredefinedActionName" : "Toggle Do Not Disturb On or Off",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 0,
        "BTTPredefinedActionName" : "Delay Next Action (async  or  not blocking)",
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 1,
        "BTTLastUpdatedAt" : 1716294724.4388971,
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 2,
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 3,
        "BTTLastUpdatedAt" : 1716296045.0837679,
        "BTTEnabled" : 1,
        "BTTEnabled2" : 1,
        "BTTOrder" : 4,
