If I have my AppleScript only return one character, e.g., return "S", and fill in S in Activate alternate color and icon if result matches regex only the alternate settings will be used.
(As an aside, Alternate is misspelled as "Alernate" there
If I return something like "Sp", and enter Sp in "Activate alternate color and icon if result matches regex", alternate settings and primary settings will be swapped as expected based upon the result of the AppleScript.
Touch Bar
The desired effect is for the button to have a blank background when music is being shown. If I use one character for the result check, the background will always be grey, which is the alternate color.
If I use multiple characters for the result check, the background will change based upon the result.
One char - when result != "S"
Multiple chars - when result != "Sp"
Script
Appearance Settings
- Type of Mac: MacBook Pro (15-inch, 2016)
- macOS version: 10.13.6
- BetterTouchTool version: 2.605 (909)
