Touch Bar doesn't work when using Macbook Pro for screen mirroring from iMac
Hi everyone! I just got the trial of this app to fix one specific problem I have. I work from home regularly and use my iMac desktop for work and use my Macbook Pro as a second screen via AirPlay screen mirroring. The problem is, I don't have a way to see the battery percentage on my Macbook without closing out of the screen mirroring altogether - which means it'll just randomly shut off since I had no clue the battery was low.
I got the trial of BetterTouchTools and was able to enable the remaining battery widget to display on my touch bar, which works great while I'm just using my Macbook, but this disappears as soon as I switch to screen mirroring mode from my iMac desktop.
Does anyone have a fix for this? This is literally the only reason I needed this application, so I'd love if there was a workaround. I'm still in my trial period but would gladly buy the license if this works. My Macbook is running Sequoia 15.1.1 and my iMac is on Sonoma 14.3.
