I'm trying to toggle bluetooth on and off using blueutil.
I installed blueutil using brew, and I am able to run the blueutil -p toggle command in terminal manually to turn bluetooth on and off.
However, when I set up BTT to execute that command asynchronously, nothing happens. I've verified that running other terminal commands works, such as open ~/Downloads, but nothing from blueutil seems to be working.
Picture of setup
I am aware of the AppleScript bluetooth toggle method here. That's an ok solution, but I'd rather understand why what I'm doing isn't working (and the aesthetics of the menu flashing up in the AppleScript one isn't ideal)>
