Toggle Pin/Unpin focused window
I have assigned the action "Toggle Pin/Unpin focused window" to the shortcut "cmd+U".
If I move a window after pinning it, the window is shown twice (one is shown in the original position and the other in the new position). Furthermore, it looses the floating on top behaviour, it becomes normal window.
If I unpin the window and pin it again without moving it, it is also shown twice.
Here is a small video showing the bug using 2 windows in Chrome (the apple.com window is the pinned one):
  • Macbook Pro 16 2021 M1Max
  • Ventura 13.5.2
  • BetterTouchTool version 4.266
Oops, it's the same with me. This is probably a bug after the feature extension of this action.
You are right, sorry! Could you check whether 4.267 works correctly?
Hi @Andreas_Hegenberg
It's fixed in 4.268
But there is another issue I see. Description:
  • Window 1 is pinned
  • Window 2 is not pinned
  • Window 2 has the focus
  • The cursor pass over the window 1 and the focus is set to window 1 (without click)
Is this by design or a bug? It seems that the normal behaviour is to click the pinned window to change the focus, isn't it?
Unfortunately that's by design, macOS doesn't offer any real way to make a window floating, that's why BTT creates a floating "stream" of the original window and places it at the position of the original window.
Now that stream does not react to mouse events, thus BTT needs to bring focus to the original window when moving the mouse over the replica.
I could offer an option to only change focus when clicking the replica stream. Maybe that could be useful for some people.
Yes, I think that's necessary. I use software (DAW Cubase as example) with some windows that can be set "on top" or "normal" (pinned or unpinned), and they only get focus if you click on them. That's the normal or intuitive behaviour, IMHO.
Usually the pinned windows are useful to look to them as you are working on other window who has the focus. In these cases you "rarely" need to give the focus to the pinned window, you need to have it on top to see it, but you are working on other windows. Hope you understand what I mean.
I hadn't noticed that until now, but it's true. This option might actually help.
Not necessarily. I often write in pinned windows. If I just want to "look" a screenshot is enough.
And don't forget, the result can only be perfect if an app makes its own windows float. BTT can do that with the windows of any app. That's pretty unique. So we should take what we get. :slightly_smiling_face:
Mm, what I don't understand: the "Scrivener" window is natively floating. Apparently it can be in focus at the same time as the Finder window behind it. Even the cursor blinks in both.
The benefit of a pinned window is to not be hidden when it looses the focus.
In other words, is useful to pin a window if you want to see the whole window all time, especially when it looses the focus.
You can pin a window to write in it, but in the case that this pinned window is the only pinned window in your screen, what is the benefit you get? You will see the same with this window configured as pinned or unpinned, isn't it?
If great master @Andreas_Hegenberg can do it, a pinned window should work like any other normal window. It should get the focus when user click on it, not when the cursor hovers it.
Mm ... yes.
Mm, no. Not if the pinned window is a small note window that sits on top of a maximize browser window.
This is the important part and we totally agree on that. :wink:
I have experimented a bit, and I think the new option works pretty well (v4.270):
It will never behave like a normal window, but maybe better than before.
After the first test ... I find it much better! no more annoying flickering. The focus even comes with the scroll gesture, clicking is not even necessary, but possible.
Perfect !!!!!
4.270 is my new favourite number!! :grinning:
Thanks a lot Andreas, you are the best!! :v:
@Andreas_Hegenberg
I have configured the "Toggle Pin/Unpin focused window" with a red background to highlight the pinned windows.
I am experiencing 2 issues with this background configuration.
Issue 1: When the pinned window get the focus after loose the focus, the background is not shown:
Issue 2: The background shows a white rectangle around the window. Is it possible to remove this rectangle or make it transparent? Detail of the square of the pinned window:
Captura de pantalla 2023-09-20 a les 21.05.32
you probably set a margin in the action config, thus you see the red border. The corners can not easily be changed unfortunately, AFAIK it’s a limitation of the macOS ScreenCaptureKit, which can not capture transparent areas
//edit: I was wrong, it was something stupid I did
v4.886 improves this action a bit and should get rid of the color corners and the border by default! Also it should improve sharpness of text
Mm, unfortunately BTT v4.886 crashes every time I activate the PIN function. Everything was fine before.
Could you post the crashlog? Maybe something on < macos 15
// removed by andreas, got all what I needed
Ah I think I already saw it (issue on macOS 13). Should be fixed in v4.887, uploading now!
Btw. this preset might also be interesting to users of this action:
https://community.folivora.ai/t/unpin-button-for-pinned-floating-on-top-windows/40435/3
