Toggle DnD is not working
Toggle DnD action is not working - the action gets called (HUD is visible) but DnD does not toggle
N/A
Type of Mac: mbp 13" mid 2014
macOS version: 10.13.5
BetterTouchTool version: 2.518 alpha
  "BTTPredefinedActionType" : 200,
  "BTTPredefinedActionName" : "Toggle Do Not Disturb On\/Off",
  "BTTAdditionalConfiguration" : "1572864",
  "BTTEnabled2" : 1,
  "BTTUUID" : "34D355BC-22B3-4F03-A707-46D0FDA1FB11",
  "BTTTriggerOnDown" : 1,
  "BTTEnabled" : 1,
  "BTTShortcutKeyCode" : 41,
  "BTTShortcutModifierKeys" : 1572864,
  "BTTOrder" : 102,
  "BTTKeySequence" : {
    "BTTPauseBetween" : 0.29999999999999999,
    "BTTKeyCount" : 2,
    "BTTKeySequenceDownKeys" : [
        "BTTKEYCode" : 54,
        "BTTKEYDown" : 1,
        "BTTKEYOrderRelevant" : 1,
        "BTTKEYRequired" : 1,
        "BTTKEYTime" : 550525696
    "BTTKeySequenceMixedKeys" : [
        "BTTKEYCode" : 54,
        "BTTKEYDown" : 1,
        "BTTKEYCode" : 54,
    "BTTKeySequenceUpKeys" : [
        "BTTKEYCode" : 54,
  "BTTTriggerConfig" : {
    "BTTHUDText" : "xd",
    "BTTShowHUD" : 1
I am seeing this in MacOS Mojave as well (10.14 beta (18A326h))
Is this still not working?
Still not working for me either (High Sierra 10.13.6)
However, you can make a workaround for now as I did. I mean, go to Preference Pane -> Shortcuts and set up a shortcut for Do Not Disturb. Then you can invoke it from BTT.
https://i.imgur.com/iW8EZoK.png (UI is in polish, but there should be DnD related option in PrefPane->Kbd->Shortcuts->Mission Control)
