Toggle BTT failed when another same keyboard shortcut with longer pressing time is set
  1. Set 2 ⌥O shortcuts with different details:
  • Immediate one:
    Trigger on Key Up;
    Minimum hold time = 0;
    Maximum hold time = 0.5s;
    action = Enable/Disable BTT;
  • Delayed one:
    Trigger on Key Down;
    Minimum hold time = 0.5s;
    action = Run Shortcut: <some shortcut in Shortcuts.app>
  1. The delayed one is alright, and the immediate one doesn't disable BTT (but enable it if disabled beforehand). I'm sure the immediate one is triggered, cuz if the action is Show HUD Overlay, HUD shows.
Affected input device:
Keyboard
  • Type of Mac: Mac Mini M1 2020
  • macOS version: 12.5.1
  • BetterTouchTool version: 3.838 (1985)
