I have 3 Finger TipTaps setup and I'm having a hard time getting them to work consistently.
My older mac used to have no issues but since I switched to my new one, this has been an issue. I have tried increasing the sensitivity and distance between fingers but still no luck.
Would love if someone can help me figure this out?
do you maybe have three finger dragging enabled on this system?
I turned it off and that fixed it. But I really use that feature. Is it possible to still use 3 Finger Drag somehow?
Unfortunately three finger drag is fundamentally incompatible with BTT as it changes many of the core behaviors of the trackpad. There is a limited compatibility mode you can try:
