Hi, for some reason there is no "TipTap Left (2 fix fingers)" for trackpad, I can only find the Tip Tap Right.
Am I missing something or is this an error?
Possibly a search issue, which version are you on? I recently made some changes to the search and one of the versions had a few issues
Just downloaded from Setapp so it should be the last one.
Still not showing the missing tiptap options, it is so weird. If I look for them "manually" they are not there.
looks like it's a bug with the auto generated spanish translation. I'll have a look, for now best switch to english
Yep! That solved it, thank you!
