TipTap Double Activation
  • Type of Mac: MacBook Pro 16"
  • macOS version: 15.5
  • BetterTouchTool version: 5.468
As my MacBook ages, it seems to be getting a little dumb about tiptaps, in particular, two-finger tiptaps (right index tap). Frequently, a tip-tap will activate both the tiptap action I have assigned in BTT and also a normal click action. Also, it seems as though it's more. likely to happen if I tiptap near or past the left of centerline on the trackpad.
Are there any parameters I can tune to make this better? Is this just a symptom of an old trackpad?
