the tiptap left/right (2 fingers fix) doesnt work, while the
1 & 3 fingers fixworks without any issues.
not sure if this is a bug or if there is some settings needs to be changed for it to work.
MacBook Trackpad
- Type of Mac: macbook pro m1
- macOS version: 11.3.1 (20E241)
- BetterTouchTool version: v3.562
