Tiptap 1 finger is not working
Hi, I'm trying to configure 1-finger tiptap to work in Chrome so I can go back and forth between tabs, but 1-finger tiptap doesn't work, if I select another gesture, for example 3-finger tap on Magic Mouse, it works.
What could be going on?
I have Magic Mouse with Mac OS X Sequoia 15.1.1
Are you doing it like this?
1.) Start with 0 fingers touching the mouse
2.) Touch with 1 finger, keep touching.
3.) Tap with the second finger left or right of the first finger. (depending on whether you use tip tap right or left)
Yes, but still not working.
unfortunately then I don’t know, there is nothing special about tip taps.
Maybe post a screen capture of BTT‘s live view and post it here (View -> Live View)
I dont find that option, but i took a screenshot.
Hi, any help please?
