I noticed that tip tap left 1 finger fix regularly triggers a 2-finger tap. Is there something changed?
can you reproduce it? (I just tried doing a lot of two finger taps but couldn't get an accidental tip tap to happen)
Sorry for the confusion, it regards the other way around. Tip tap results in 2-finger tap. I don't see a pattern. It happens quite often but not a hundred percent of the time.
I have the tip tap left configured in CAG for browser Helium(to previous web page) and the 2 tap in the general to show a floating menu.
That would be weird - the executed action is not connected to the triggering at all. However I have added one more guard in 6.621 (uploading), maybe that will also help!
Thanks for the mod. I will try it and keep an eye on the issue
