Hi Andreas,
first of all, thanks for your great work with BTT!
Note:
→ Check, tried a lot of stuff. Have an IT background myself.
- Timed trigger (e.g. every hour) to execute an Applescript is working when the MacBook is freshly started
- On device-lock I deactivate the preset holding this trigger and activate the preset again when unlocking (this works fine) (I don't want the script to be executed when screen is locked)
- After unlocking the screen the preset is active, but the timed triggers are not executing.
- MacBook Pro 16" 2019, Core i7
- Type of Mac: MacBook Pro 16" 2019, Core i7
- macOS version: Sonoma 14.2.1
- BetterTouchTool version: 4.375
Thanks and Best, Sebastian
