With BTT running, my Time Machine application runs when I launch it, but I can't do anything. If I click on any of the red bars on the right, nothing happens. If I click on any of the windows that receed behind the default window, nothing happens. Clicking on the up/down arrows on the screen does nothing. I can only click on "Cancel" and I can use the Escape key to exit the Time Machine application.
If I "Quit BetterTouchTool" from its menu bar item the Time Machine application works correctly, responding to all clicks. If I launch BetterTouch\Tool again, the Time Machine application does not respond to any clicks except the Cancel button, as before.
MacBook Trackpad, Magic Trackpad, Magic Mouse
Sorry, but I can't get screen shots or screen videos from Time Machine, since it takes over the computer, as far as I know.
- Type of Mac: MacBookPro 13", 2017, Four Thunderbold 3 Ports, 8 GB Memory, 256 GB Internal SSD
- macOS version: 11.4 Big Sur
- BetterTouchTool version: 3.670 | 1711
Workaround/Solution
MY SOLUTION: In BTT Preferences, set it to not auto launch. Turn off BTT. Reboot the Mac. Leave BTT not running.
I also had/have Golden Chaos running within BTT. I can't tell if it is still there. I don't understand BTT well enough, I fear, to navigate all the windows/menu items/options/preference.
I apologize, but I can't tell how to get to the Alpha version of BTT and I can't tell how to "upgrade" GC to a latest version, or even see what version I have installed. BTT is at version 3.670 | 1711 as far as I can tell.
Your note says to check that I have the latest Alpha version running, but I don't see how to find that. I tried the About menu item and looked under the Help menu of BTT but didn't find anything about checking for updates. Probably my error?
Incredibly powerful program. Very confusing to me with SO MANY screens of settings and preferences and such. But that is my problem (unwilling to spend the time to learn a complex system like this) not yours.
Great day!
