Three finger click sporadically not working
I have BTT version 6.609 and macOS version 26.5.2 on a M2 MacBook Air. I did a fresh install and now my 3 finger clicks are very sporradic. I do not have 3 finger drag enabled. 4 finger click works fine. I have no had any problems before but now I do. 3 finger click will be working ok and then at some point it will stop and I have to restart BTT in order for it to work again. When it stops working if I go to the live view in BTT it shows my touches, it will show 4 finger clicks when I do a 4 finger click, but it shows nothing when I do a 3 finger click until I restart it. I selected to restart BTT on waking from sleep I thought maybe that was the cause but it isn't. I disabled all 3 finger gestures in the macOS settings. Before I did the fresh install it was working fine but I didn't backup my settings to know if it is a settings problem. I have barely any commands setup in BTT but a 3 finger click is supposed to be command-W
