More than half the time when I use three-finger click to middle click a link in Google Chrome it also triggers a right click.
Anyone else experiencing anything like this?
which version of BTT and macOS?
4.783
15.0.1 (24A348)
It's very inconsistent, but once it starts, it seems to get worse.
I do have click pressure set pretty high for three-finger clicks, but it hasn't been an issue until recently. I'll try lowering that a little.
do you maybe have the three finger dragging enabled in macOS? (it’s a setting in accessibility that allows to drag with three fingers but also breaks fundamental standard behaviors of the trackpad)
It can also be related to this setting when set to "light" (or maybe also medium), especially when combined with a high three finger click pressure in BTT:
Set click to firm and lowered three finger click pressure. Still doing it.
then I‘d almost assume it’s a configuration issue. If you want you can go to help -> export diagnostic debug information and send the result to me (andreas@folivora.ai ) then I can check!
Sent you the logs. Also, I don't know if it's important, but I noticed that the same thing happens with three finger tapping.
Just noticed it happens with all three finger click gestures. Click swipe up, etc.
Anything on this? It's really annoying. I might just stop using three-finger click gestures altogether.
Sorry, it was kind of hard to figure this out.
I believe it was a issue with drawing/mouse gestures in combination with a specific set of trackpad gestures.
I hope it is resolved in 4.832 (uploading now)
Maybe it's just me, but now two finger click doesn't work at all. I have to quit BTT to get it to function.
macOS two finger click, I mean. I just set up two finger click in BTT and that works. I hadn't been using that before, but I guess I will if that's what it takes. It seems like I've tried that before, and there was some sort of problem with that also. But I don't remember.
sorry, now the blocking was a bit too much for a specific setup with right-mouse drawing enabled. This should now also be resolved in 4.841 (uploading now)
Yeah, I'm also having an issue now we're drawing seems to restart BTT.
And doesn't trigger anything.
4.841 is online now!
