Three-finger click doesn't do anything. It is recognized in Live View, which (most of the time) identifies the action (CMD-Click), but it has no effect in applications. I have checked the trackpad preferences, and three-finger click is not selected for anything.
Seems to work fine here. In what app are you trying to use it? And to trigger what kind of behavior?
In case you have enabled Three Finger Dragging on your system - this causes various incompatibilities with BTT. In that case try to enable the three finger drag optimizations:
I double-checked, and three-finger drag is off. It's set up to trigger CMD-click in all applications, but I've only tried it in Safari and Mail.
In Live View, sometimes it shows "CMD(⌘)+Click" in response to "3 Finger Tap," and other times it just shows the time-stamp, "3 Finger Tap," and the message "Only gestures you have already set up in BTT will be recognized correctly." In any event, the CMD-click action doesn't seem to happen.
When I turn on the HUD Overlay, sometimes it appears, and sometimes it doesn't (even though Live View recognizes "3 Finger Tap")—but again, in any event, the CMD-click action doesn't seem to happen.
What is weird is, when I close the BTT window, I get better results in Safari: Sometimes the HUD appears and CMD-click works! But only sometimes: mostly nothing happens.
