This discussion is about seeking help for issues with Better Touch Tool actions not working in Chrome and Safari.
Note:
"Several actions in Better Touch Tool are not working in Chrome and Safari. Does anyone know a solution?
These actions were functioning in Safari until November 3rd but suddenly stopped working. However, the same actions work in other applications.
I would be grateful if someone could provide a solution!"
Trackpad
  • Type of Mac: M3 iMac
  • macOS version: sonoma 14.11
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
    4.318
what kind of actions?
Thanks for the reply.
Actually every action.
① Swipe down with 3 fingers.
② Tap with 3 fingers.
③ Tap with 4 fingers.
④ Swipe left with 4fingers.
⑤ Click with 3 fingers.
these are the triggers, what kind of actions do you have assigned to them?
Is your BTT maybe disabled for Chrome & Safari?
→ close a tab
command + W
→ open a new tab
command + T
→ take a screenshot
command + Shift + 4
→ Reopen closed tab
command + Shift + T
→ Open Paste which is an app.
command + P
I don't think BTT is disabled for Chrome and Safari.
But I will check just in case.
Where should I check ?
If you have added them to your BTT side bar you can check there:
Can you see attached files?
Sorry it's written in Japanese.
It's not checked second one from the bottom.
スクリーンショット 2023-11-21 8.23.21
スクリーンショット 2023-11-21 8.23.10
