The tap area in the upper right corner is too big for just a single finger.
This gesture works fine on my MacBook M1 Air. But I recently switched to a 14-inch MacBook Pro M4, and I've noticed that when I click the trackpad about 3cm away from the right edge, it still registers. Ideally, it should only work in the top right corner. Has anyone else run into this issue?
