The chatgpt conversion and replacement feature in BTT should not delete the original text.
For example, if I input "aaaaaa" and then press Command + A to select all this text, the result after conversion is:
aaaaa
bbbbbb
The original "aaaa" doesn't get deleted automatically; I have to manually select and delete it, which is quite cumbersome.
You can uncheck this option:
Oh, I really appreciate your help! Many times, I've found that you’ve already perfected the functions, but I just hadn’t activated them. I thought those settings didn’t exist. However, browsing through all the settings can be very time-consuming. I'm considering how to quickly inform users about all the features of the BTT software.
