BTT clipboard manager window shows preview text on left panel for unselected items as grey on grey making it impossible to read. But in Dark mode text appears as white on dark grey making it easily readable.
Working on MacBook pro with multiple screens. Using BTT 3.707 (updated to latest alpha and restarted machine)
Here is screenshot of BTT while macos is in normal (daytime) mode:
Ok. I modified the "Accent color" under General settings and now text shows up ok in light mode and dark mode. Hmmm. I'll play with that some more and report back.
Very weird, switching between dark and light also seems to work fine here.
I'll have a closer look tomorrow to check whether this is caused by something in BTT! If possible also try to update to macOS 12.1 - Apple has fixed many many bugs in that release.
Just a +1 that this is still an issue for me on BTT 4.0.65 and Ventura 13.2.1. I use "automatic" dark mode switching so it's unreadable every morning when I log in.
Same here; still happens in Sonoma when Dark mode is set to "Auto". When sunrise comes, and macOS changes to Light, the clipboard text in the items disappears.
I have to restart BTT and that fixes it. It seems that, although the clipboard manager changed most of the theme to Light successfully, the font color is still set as it was during the Dark mode; hence it's invisible.
Same issue here. Automatic dark/light mode switching. Same problem with visibility. Restart of BTT helps. M1 Mac, Mac OS 14.4.1, BTT version 4.462. @Andreas_Hegenberg is there a problem with bug reproduction?
