Text expander problem
I've tried to create a text sequence (for all apps): #ct
That pastes: https://www.heise.de
This works when typed into e.g. TextEdit but not when used in the address bar of Safari?
And one thing: I've used the right shift key while typing the sequence. I would like it to work regardless which shift key is pressed. How do I do that?
Ehm...
I've uninstalled BTT (including all settings and triggers), reinstalled the cask via brew, bought a lifetime license and imported the license + backup of settings & triggers.
Now the example of the first post doesn't even work in TextEdit anymore?
