EDIT: Just found the setting in BTT [Switch To Preset]!! In case anyone comes across this post with the same question, I will be creating a tutorial for this, posting it in the proper thread, and adding the link to the post here.
Is it possible to set up a keyboard shortcut to switch between BTT Presets?
I use my laptop as a hub in a litany of scenarios with various external devices and I would like to be able to easily switch Presets to match the task at hand and particular devices for the scenario.
I tried saving the Preset to my system and then setting up a shortcut to launch the file, but BTT tried to import the file instead. I'm thinking that function might be missing (hopefully only) for now or it might involve some scripting.
