I can’t get enough control to click/dbl-click on things. The trackpad cursor just draws all movements on red.
Please help
what trigger did you configure to start/stop drawing recognition mode?
I don’t remember. I run this machine headless and feel like it was somehow activated. Usually I control it via VNC on an iPad.
Is there easy way to reset settings by deleting a file, I could do that via ssh.
Always loved BTT. Thanks for making it.
I noticed it was acting on a rectangle in left half of screen. I managed to open the preferences from the menu bar and drag it over to the right hand side then it had normal mouse nehavior and I changed preferences to a different save. And now it’s not stuck in that mode. Cheers
