I am using BTT as running my Streamdeck with 15 keys.
And sometime an update changed something about how it worked.
I have almost all keys setup for all apps.
And then in InDesign I have created some other ones using the same placement for all apps.
When I started with this and switched to InDesign, then the InDesign ones where came up on the StreamDeck.
But now the become available but I have to tap the arrow in the right corner to see them.
I prefer the come to the front.
Weird, I can't think of any change. However there is this option:
Does that solve your issue if you activate this for Indesign?
That works.
But the old way did keep the global keys on those where I had not defined any others under InDesign.
Thanks for this tip.
I think I might not fully understand. Does this option result in the same behavior like you had it before, or is it different?
The old behavior was that when I switched to another app with different actions for buttons, but set to the same location, all the blanks not set in this app showed the general ones.
So in this example all 5 in row 1 and the first 3 from row 2 was visible when I switched to InDesign. But the other global ones stayed visible.
Weird that still seems to be the case here ( unless the "Hide Global Triggers" option is activate for an app)
I can't think of any recent change to his behavior, but I'll go through the file history to see whether there was anything related.
Do you remember when this last worked for you?
I can not remember exactly when it worked like you describe. But it changed sometime in the last 2 months.
Should I try to export my presets. Uninstall BTT and import my presets?
I just remember at the same time I experienced I sometimes has to press a button two times before it registers. But it is not consistant.
Can I make some kind of log dump of my system or BTT to help locate the issue.
Yes you can go to Help => Export Diagnostic Debug Information and send the result to me (andreas@folivora.ai)
(I checked, but can't find any code change, maybe it's happening in combination with a specific setting, in that case your logs would help)
I have also sent an e-mail with a video showing, what I thinked caused the issue.
It seems the order in which the triggers appear from top to bottom in the Stream Deck section has an influence on the way the get handle when using the same button across general available triggers and some specific for apps.
