The Elgato Software makes it possible to rotate the stream deck in order to mount the device upside down. Don't know it that is supported by BTT - can't find it though. Is it?
Cheers
Not yet! But it should be easy to add the logic to rotate - I'll look into that
Any progress on that topic?
I’m also looking forward to the device orientation setting.
