Streamdeck Neo Touchpoints sample preset
Sample code for using the Streamdeck Neo Touchpoints to trigger actions
This is a very simple preset that uses the Generic Device Analyzer to detect touches to the Streamdeck Neo touchpoints.
Two triggers are defined, TP Left, and TP Right. In the sample code, these just use the HUD overlay to show that something happened.
To use in your setup, just add new actions in TP Left and TP Right that do whatever you need (call a trigger, send a key, etc), and optionally disable the HUD actions.
(I use mine for paging my Streamdeck.)
And here's the preset...
Streamdeck_Neo_TP.bttpreset (9.1 KB)
