Stream Deck: white bars on the left of every button in BTT control mode
For every button on my Stream Deck Mini I see a white bar on the left side of the screen. I'm not sure why, but this behavior only occurs when the stream deck is controlled by BTT. Closing BTT and using the Elgato software removes the white bars.
Stream Deck Mini
Unfortunately I can't upload images because I'm a new user. Here is a link to Google Photos: https://photos.app.goo.gl/Fr4RbHurMxbhVi2u5
  • Type of Mac: Macbook pro 16 inch (2021) M1
  • macOS version: 14.5 (23F79)
  • BetterTouchTool version: 4.583 (45830)
I don't have a Stream Deck Mini, but this is pretty weird.Could you select some of these buttons, right-click and "export to file", then attach here or send it to me? (andreas@folivora.ai)
Honestly I was a bit surprised as well given that nobody had repeated this so far because even the buttons that don't have any content definitions show the line. And it's always after BTT starts that the lines start to show... Might be a protocol thing specific to the Mini
Here are the triggers that don't contain any sensitive/hardware specific information.
exported_triggers.bttpreset (19.8 KB)
If I switch BTT to "plugin mode" for stream deck the lines don't show. Not sure if that helps?
