- I am on the latest (alpha) version of BTT,
- I have restarted my system.
- I have not encountered a crash
When using the dock widget and putting the apps I want to display, including Safari, in the "Only show items with these names (separated by commas):" section, the Safari app does not have the Running Indicator correctly display based on the app being open or quit. All the other apps I have tried correctly display if the app is open or not, just not Safari.
A few things I tried to verify this was a Safari-Specific Issue:
- Once I set the apps I wanted in the "Only show items with these names (separated by commas):" section, I restarted BTT and they displayed correctly. Safari will display the Running Indicator if Safari is open before I restart the app, but then the indicator will not go away even when the app is quit. Same happens when Safari is closed when I restart BTT, it shows NO Running Indicator and one never appears even when Safari is opened. This happens correctly for all other apps tested.
- I verified that I was using the correct name for Safari in the section where I placed the app names. It was correct. I figured so because if I tried a lowercase 's' for Safari, it wouldn't even show up when restarting BTT, but I verified using the Advanced Conditions -> Visible Windows Viewer to identify the app name.
Stream Deck
- Type of Mac: 14-inch, 2021 MacBook Pro
- macOS version: Ventura 13.0.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") 3.939
