Stream Deck Plus - Dial 2-4 Press not working
Setting up Stream Deck actions for Stream Deck Plus Dial 2-4 press functions does nothing.
BTT is set to fully control Stream Deck and if I set Dial 1 press action, it works. Similarly Dial 2-4 rotate actions work. I tested this by setting a simple application specific keyboard shortcut action. On Dial 1 it works, on Dial 2-4 it does nothing with the same keyboard shortcut.
Stream Deck Plus
  • Type of Mac: Macbook Pro 16" M2 Max
  • macOS version: 13.2.1
  • BetterTouchTool version: 4.069 (2284)
I am also seeing a similar issue to another user where SD Plus Touch screen configuration shows nothing.
I have a Stream Deck Plus starting with serial number EL27, bought in Finland.
You are right, there was a logic error. Will be fixed with the next alpha version.
