Stream Deck Issues
Hi!
I have installed the latest Alpha Version 5.251
There seems to be a few bugs in Stream Deck integration (Full Integration)
Dear Andreas, i´m so sorry to bother you again, but can you probably look into those 2 issues. And leave short feedback, probably you can resolve them easily.
Thank you so much!
I use a Macbook M1 Max with BTT and wanna use my stream deck for some "simple" tasks.
Issues:
  1. When entering a folder (e.g. row 1 column 2), and the button within that folder (row 1 column 2) has a trigger up action, this action gets triggered.
  2. Press Up and Long Press Actions dont work in "hidden" Sub Folders for specific Applications
to solve those 2 issues would be a really helpful task, cause i need those actions so hard.
best wishes. and have a nice day.
Dear Andreas! i dont wanna be impatient, but it would be very nice, if @Andreas_Hegenberg you could please just tell me, if there is a chance that these issues will get fixed anytime in the near future?? best wishes. Re
