Hello, I am new to BTT and looking for help setting up some buttons/ actions with my Stream Deck.
I have 2 questions right now:
Is there a way to set up an action that would be executed on a "2nd press" or "3rd press" of the same button?
(I can see the option for "button down" and "button up", and "on Long press"... It would be great if I could press the same button again and have it do a different action.) -
Also, is there a simple way that, after the 1st press of the button, the Appearance background color (And or text) on the button would change? And then when I press it again, it would change back to the first BG color/ Text?
I thank you so much for any help you can provide me.
Thanks again!
-Cinematog.
