Anyway, I have a shortcut that turns the preset “Layer 1” (red label) on and off. That works. I can see in the preset menu how the box is checked or unchecked. But the action is not hidden, but still works or vice versa.
If I check or uncheck the box with the mouse, everything works as expected.
Correct, if the preset is activated, the hud is always displayed. I cannot deactivate the preset with fn + 0. Although the preset menu shows that it is deactivated ... God this is complicated
completely ignore the preset menu or any ui element that shows the active presets - they are currently not updated correctly via the action.
But if you close the BTT preferences window and press fn+0 your q key shows the HUD, and if you press fn+0 again the q key still shows the HUD?
Ahhh, sorry, I could have come up with “Recently Used” myself. There I see that fn + 0 is an (unused but active) app specific shortcut that overrides the global one. Sorry about that.
