Strange left/right modifier behavior
@Andreas_Hegenberg With the setup below, “F” acts as right shift when the key is held down.
So if I press “F” + “K” the shortcut “right shift + K” should be triggered. Instead, a capital K is typed, just like with the shift.
When using the real right Shift key, the shortcut is triggered correctly.
Am I missing something?
should be resolved in 6.1167! (uploading)
Resolved, thanks.
I also noticed this: As long as “F” is held down, the modifier key should also remain pressed. So I should be able to press “k” repeatedly.
But unfortunately, the shortcut only works once unless I release “F” and press it again.
I haven't made this default yet because it could break existing setups, but I have added an option to prevent releasing modifier keys after a BTT action has fired in 6.1168:
“Break” in the sense that if you disable the option, it works again, or "break" a new setup is needed?
disabling will make it work again. It would only break specific action sequences were users relied on modifier keys being released after an action.
