Strange haptic responses (either no feedback or continuous vibration instead of the two stage force click response) at corner once set corner click/force click triggers in BTT on MBP 2021 14'. This strange response only affect the specific corner with a trigger (e.g. 1 bad corner with trigger in BTT + 3 normal corners); without a trigger or turn off BTT will give a normal haptic response. It only happen on my MBP 2021 14'. My other two devices, MPB 2020 13' intel (build in trackpad) and Mac mini M1 (external Magic Trackpad), do not have this issue and work well with the click/force click actions.
Build-in trackpad of MBP 2021 14'
- Type of Mac: MBP 2021 14'
- macOS version: macOS 12.6.1
- BetterTouchTool version: (please post the exact version - not just "the latest one") 3.952
