@Andreas_Hegenberg I may have already asked this question, but unfortunately I no longer know the answer. So, sorry in advance.
When I copy a text from Gemini (AI) and then paste it into a text app (for example TexEdit), strange characters appear, although the text appears correctly in the BTT Clipboard Manager. Can I do something about this? Thanks.
This is what the text looks like in the BTT Clipboard Manager
I'm sure you're right. I can paste without formatting.
But isn't that strange? The text is transferred correctly from the source (Gemini), otherwise you would already see the error in the BTT clipboard manager. The error seems to occur when pasting to another app.
the problem is in how the clipboard works. Everytime you copy something the system will save multiple âformatsâ, then when you paste something the target app will decide which format fits best.
Now it looks like gemini ai puts some formats correctly, but messes up the one thatâs needed to paste with format.
