I tried to use the floating WebView via the tutorial:
https://folivora.ai/blog/post/13000
but it didn't work. Instead, when I did the 3-Finger-Tap, the code of the html-file appeared on screen. I then realized that the WebView appears, when I do "command-alt-F" (which I use for jumping into the search bar in Safari). I didn't like that, so I deleted the action. But it didn't go away. I even deleted the associated files (html + css) and it still appears when I push "command-alt-F".
What's going wrong here?
And I have the newest version installed.
