Hi
I am a pretty savvy 75 yo grandma and I just discovered BTT can do text replacement but I can't figure out how to set it up. Can someone help me with a step-by-step guide? eg change "imo" to "in my opinion"
Hi
Welcome
Set up a key sequence
Then use the predifined action “Insert custom text” (or similar)
Now, whenever you type “imo”, “in my opinion” is expanded.
Edit: Ah, wait, maybe you'd better put the key sequence on like this
This means that BTT only expands if you do not type anything after the letter “o” for 0.2 seconds. Or as many seconds as you want.
