BetterTouchTool does not start when my OS starts up
- Type of Mac: Macbook Pro M5
- macOS version: 26 latest
- BetterTouchTool version: 6.663
you need to enable the launch on startup option in the BetterTouchTool settings
I have but each time i restart, I have to manually start BTT
are you sure it’s still enabled? There are not many reasons for why it wouldn’t start if that option is active, unless maybe it crashes on startup for some reason or some other app prevents it from launching.
Possibly check whether there are any crashlogs in the macOS console app‘s crash report section
