please can you add the ability to move the starting point for drawings according to preference. it is currently at the centre, and if a drawing proceeds to the right, or down, as it often will with Western writing, half, or more, of the space is unusable
is this going to be possible?
It's currently not planned, but you can also draw outside of the visible area - it will still record, just not show.
