I'm not a sophisticated user.
I'm running MacOS Monterey 12.4 & BTT 3.816 (1960) on a MacBook Pro (2019)
I'd like to "start over" then reinstate all my current tiggers & actions because:
- many items in my home folder's Library/Application Support/BetterTouchTool folder have zero bytes & appear related to very old versions of BTT
- BTT will not update automatically
- on choosing from BTT menu "Check for regular updates" →
Update Error
BetterTouchTool can’t be updated when it’s running from a read-only volume like a disk image or an optical drive. Move BetterTouchTool to Applications folder using Finder, relaunch it from there, and try again. - When I check System Preferences - Login Items after restarting BTT, I accumulate entries of BTT with Kind=unknown and a yellow triangle "caution" icon
Can I save on an external disk all my triggers & actions & preferences to reinstate them after deleting everything related to BTT? How do that?
Is it OK to delete all BBT folders & files from my MacBook using an app like AppDelete, then download a fresh copy of BTT, give it my license, then (how?) reinstate all triggers & actions, preferences?
I need detailed help, step by step. Thanks much!
