Let me start by stating that I realize this may not be in the right place, please feel free to move it.
I have 2 items on by TouchBar for music - I found them here on the forums.
The first one shows a play button and switches to a pause button when pressed, the other shows the track name (only showing when something is playing). I'm sure many of you have seen or are using these.
This morning, I noticed that the Play/pause button is missing and even if I manually start something in Spotify, the track info doesn't show up. After restarting BTT a few times, I looked at the code. It was all the same color (I SWEAR it changes when the code is checked) so I ran the Compile / Check Syntax and get an error on BOTH scripts.
The lines in question are:
if player state is playing then return "pause"
On the other script it is:
For both of these, when BTT checks the code, I get a pop-up that says "Expected “then”, etc. but found identifier." It will highlight the word STATE in both instances.
Any ideas? This has been running without any changes for a couple months. If someone wants to tell me how to post the code here so it formats correctly, I will do so.
