Hello, Maximize Window doesn't work at all for macOS Sonoma.
FYI I'm using the MacBook trackpad and selected the trigger as "Spread with Thumb and 2 Fingers".
Other window resizing tools are also not working, such as "Restore Old Window Size" and "Maximize Window Right Half"
I'm using the latest Alpha version and I've restarted my MacBook.
Note:
- Type of Mac: MacBook Pro with M3 Pro 14"
- macOS version: Sonoma 14.1
- BetterTouchTool version: 4.321
