Some times the following Trackpad gestures don't work, until you open BTT application by clicking on 'Configuration' in the Menu bar icon, then the Gestures start to work.
I have faced issues with following gestures (mostly I have used them in Chrome, will check on other apps as well).
- CMD + Two finger Swipe LEFT/RIGHT
- Tip Tap LEFT/RIGHT.
- Four Finger Tap
I use above gestures for Tab Manipulation.
Above Gestures intermittently fail, but the Four finger click doesn't (Which I use for Minimize Window), Snapping windows also keeps working.
MacBook Trackpad
- Type of
Mac: - macOS version: 12.2.1
- BetterTouchTool version: 3.740 (1882)
