if a default macOS shortcut doesn't work while BTT is running, it usually means that you have overridden the shortcut in BTT. Have you checked the keyboard shortcuts section?
Just to make sure I quickly checked, but all Mission Control shortcuts defined in System Preferences => Keyboard => Shortcuts are working fine here.
Thanks. I had assumed that all shortcuts were listed in the Configuration screen, instead of being filtered by device. I've never manually created or modified any BTT keyboard shortcuts, but Control with any of the 4 arrow keys were all set to Do Nothing, and Control-Alt-R was set to Right Click. I've never seen those shortcuts before or intended for them to exist.
