hi,
I managed to create a script to enable some sort of presentation mode. The script hides all open apps, mute the volume and turn on Do not disturb.
here is the script:
property HideApps : false
set whitelist to {}
tell application "System Events" to set processList to get the name of every process whose background only is false
set Reluchlist to {}
if HideApps = false then
set HideApps to true
repeat with i from 1 to count processList
if whitelist does not contain item i of processList then
tell application "Finder"
set visible of process ( item i of processList) to false
end tell
end if
end repeat
else
set HideApps to false
set visible of process ( item i of processList) to true
end tell
end if
end repeat
end if
tell application "System Events" to keystroke "d" using { option down , command down , shift down }
set curVolume to get volume settings
if output muted of curVolume is false then
set volume with output muted
else
set volume without output muted
end if
Whenever I run it with the Script-Editor, it workes fine. But when I run it with BTT, I'm only able to hide the Apps and not to show them back.
Does someone have a solution? should I change the script or change settings in BTT?
thanks
