Some features not working on golden gate
Just a heads up. I use three finger tap 3 times to close window and this does not currently work on macOS goldengate.
How do you have it configured? Three finger tap seems to work fine here
Configured as:
3 finger double tap -> close window under cursor (works in mission control)
So yea, I was wrong in original post, it's double tap. But, it still doesn't work.
Update, works outside of mission control, with MC open, we cannot close using 3 finger tap twice
Ah I see. I'll check whether that can be supported on macOS 27
Any updates?
no, let’s wait for a few more betas, this might get resolved by apple
Still not working.
May be unrelated to OP, but don't feel like a new thread is warranted - just upgraded to Golden Gate public beta 1. Most gestures and shortcuts carried over fine, but actions related to screen brightness and audio volume are not working for me. I use four finger swipe up and down for volume control, one finger swipe along trackpad bottom edge left and right (and a keyboard shortcut) for brightness adjustment. Also have both volume and brightness mapped to Logitech MX Master 4 custom mouse combinations (button + vertical or horizontal scroll) and none are working at the moment. Tested on stable and alpha releases; currently on alpha 6.646.
Let me know if I can share logs or other diagnostics to help.
are you using basic keyboard based brightness / volume actions or more advanced ones that work using BTT's javascript?
I'm using the native BTT "Volume Up (Small Step)" and "Brightness Up (Small Step)" actions. I tested the "...(Small Step, External Display)" and regular variants (e.g. "Volume Up") as well.
EDIT: just realized Volume adjustments are working - I am just not seeing the HUD/toast like in Tahoe. This is fine for now. Brightness is not working for my external display (using MBP in clamshell).
Hello, I'm sure you're swamped with Golden Gate posts right now, so I understand if this takes awhile to get a response!
I just updated to Golden Gate and I'm experiencing the same behavior. "close window under cursor (works in mission control)" DO NOT work in Mission Control but DOES work outside of Mission Control.
Any update on if this is able to one-day be made workable in Golden Gate would be appreciated!
This should be resolved in 6.827! (Apple changed this a lot, but I hope my workaround is fine)
Thank you for your quick reply!
As of 6.926 the behavior was no longer "successfully closes windows only when not in Mission Control" and was instead "never successfully closes windows" for me. I updated 6.928 and it appears to be the same.
I have restarted my computer and remade the BTT trigger just in case, still not working.
Does BTT stopped working from lockscreen on MacOS 27? Or is it gonna be fixed? @Andreas_Hegenberg
UPDATE: I have no idea why but now, about 30 minutes later in the same computer session without doing anything noteworthy, it works! Closes windows in Mission Control, closes windows outside Mission Control. I just checked: I'm still on 6.928, I don't believe that BTT's auto-update pushed anything new to me. All I know is that now that I've been working for a little bit of time post-computer-restart, everything works.
Thank you Andreas!
Great! It has also been working fine on my test machines.
Hi everyone,
I was about to post asking for help with this, but the update seems to have fixed it, so I'll leave it here in case anyone else runs into the same thing.
On macOS 27.0 (26A428), two of my keyboard shortcuts had stopped working: the one I use to close the window under the mouse cursor in Mission Control, and the ones I had set up to switch between desktops/Spaces. The triggers were still there and looked unchanged, but nothing happened when I pressed them. Other BTT triggers were working normally.
I just updated to 6.8.28 and both are working again. So if you're on an older build with this macOS version and your Mission Control or Spaces shortcuts are dead, updating is worth a try.
Thanks for the quick fixes, Andreas.
