[Solved] Preset/backed up settings automatically deleted
I have tried the latest alpha and restarted the system, but the issue persists. Crash log attached below.
Crash Log.html (50.6 KB)
All existing settings/pre-sets stopped working and disappeared from the app today (prior to trying the alpha).
When I import my saved preset settings, they reappear for about a second and then immediately disappear again - and this occurs whether or not I have the preset settings override existing settings.
When I try to restore settings from backup, BTT crashes (see attached crash log).
All input devices.
  • Type of Mac: MacBook Pro M1 (2020)
  • macOS version: 12.6
  • BetterTouchTool version: 3.874
For anyone with a similar issue in the future, I was able to eventually fix this by deleting all BetterTouchTool setting files (as per Installation/Deinstallation · GitBook, under "Uninstall"):
  1. ~/Library/Application Support/BetterTouchTool
  2. ~/Library/Preferences/com.hegenberg.BetterTouchTool.plist
I had multiple versions of the second file, and deleted all of them.
Note that simply deleting and reinstalling BetterTouchTool did not correct the issue.
