Note:
"Window snapping" used to work perfectly with "Notch click". Notch is at the center of the top screen so when snapping window to maximum, it is quite common for cursor to go inside the notch and in previous version it seems for "Notch click" to trigger, it needs click and release both performed inside the notch. However, after updating version 4.212, just release will trigger the action, which leads to many mis-trigger when snapping. I'm guessing one of the change "Big performance improvements, this version should lower CPU usage on most systems (compared to versions <= 4.158)." is the cause of the issue?
Genetic mouse, Logitech G502 lightspeed, M1 Pro MacBook Pro 16' trackpad
- Type of Mac: M1 Pro MacBook Pro 16'
- macOS version: Monterey 12.6.9
- BetterTouchTool version: Any version after(include) 4.212
